Ficht 225 2001 Computer Print out. What does it mean?
mricemachine
This is a followup post. Getting ready to buy this evi ficht m#E225stxs1F S#04951227. Any or all info from all you folks is appreaciated. Still waiting on print out from dealer but looks like about 400 hours on her. Visually looks pretty good. My mech will check it this week. 3700 for motor plus 400 for new tach and harnesses.<br /><br />TKS<br />Tim
mricemachine
Re: Ficht 225 2001 Computer Print out. What does it mean?
Is there anything I should be on the look out for on the computer print out from the motor? I should have it this afternoon<br /><br />Tim
mricemachine
UPDATE! I posted the wrong Model #. Correct # is E225FPXS1F BRP concured that it was a 2001 Model. Also showed no record of warranty items replaced? <br /><br />Tim
Billnicole
How many HP?
mricemachine
Print out from computer on motor and compression should be available to me tomorrow. I will post what I can for your feed back. After much researh I have found that this is the in between OMC and BRP. Should I be concerned that it might have the same issues as the 1999-2000 models? Also what are the first MTX items I should do? (Lower unit fluid change, plugs, etc etc)<br /><br />Tim
muskrat
emm was replaced in 2002 thats good.alot of omc built emm would though alot of open coil codes & stop working.and a seal was replaced 2002.....
mricemachine
Muskrat,<br />How did you obtain this info? That is a pretty cool tool to have to check history. Let me ask if the EEM was replaced again since would it only log the new hours or does it default to the previous hours?<br /><br />Tim
seahorse5
When an EMM is replaced, it is exchanged at the factory and the stored info is transferred to the new unit.
mricemachine
TKS Seahorse. This is some good stuff to know!!!<br /><br />Tim
mricemachine
Hey Folks,<br />I have more info: <br />Compression = 128-130-130-130-130-132<br />Print out from motor:<br />Hours = 617<br />Max RPM = 6242<br />Max Temp = 192<br />EMM Serial # = 6669<br />EMM date code = 15EB<br />EMM Max Temp = 172<br />Prog. Version = 3030259<br />Break in time = 5:00:01<br />Injector Values = (bunch of #s hard to read)<br />Current Hard Faults = none<br />Stored Faults = none<br />Persistant Engine Faults = none<br />Engine RPM Profile = 45% at idle rest is mixed range<br />Engine Temp Chart = 68% at 122 25% at 140 degrees<br /><br />Thats it....now what does all of that mean. Sometimes to much info is a bad thing :) <br /><br />Tim
mricemachine
More info....<br />Injector values:<br />Serial # (Something A) (b) (c) (d)<br />00293040500184 22 161 862 25987195<br />00294040371194 24 206 992 24861945<br />00297040266185 24 184 923 25979905<br />00294020399195 21 159 868 26010245<br />00297030268183 23 174 912 25459289<br />00294050341195 23 181 912 25806821<br /><br />Not sure what all of that means.........<br />Tim
mricemachine
Anybody with a translation as to what all of these #'s mean?<br /><br />Tim
mricemachine
Picking motor up tomorrow...anyone with feedback on the above numbers?<br /><br />Soon to be fishing again,<br />Tim
seahorse5
The printout is for techs but what concerns an owner are total hours, hours at various rpms,and max temps and rpms that the motor has seen.<br /><br />Injector values are the serial numbers that tell the computer how to inject the correct amt of fuel into each cylinder.<br /><br />Faults are error codes that the computer keeps in memory.<br /><br />Emm date codes and software numbers are for updates if ever needed.<br /><br />That's it in a nutshell.
