Ficht injector cleaning at home
jedimaster
OK, so I have sent one injector out the be repaired and servived/cleaned is there anything I can do at home to clean/maintain the rest of the ficht ram injectors? I know that I can't take them apart and do a full cleaning but can I run fuel injector cleaner through them, soak the tips etc... anything I can do to just do some sort of cleaning?
Faztbullet
No not really as soaking removes surface crud... the pintle need to be withdrawn and high pressure cleaner circulated around it.
Crosbyman
Excellent video but fundamentally the same concept as any injector. ...a magnet activated valve which releases pressurized fuel into a cavity.
that said I did not wish to start a great debate but simply answer Jedimaster on his request to try and save some $$ by doing his own injector cleaning .
​I hope both videos will help him decide what he wants to do or attempt, based on his acquired knowledge, mechanical abilities and risk taking threshold.
Except for any internal mechanical malfunction or electrical (open coil) issues.. I know I would try a home solution having had to pull the clogged injectors.
​it is now up to him to decide... but if a different or specific method is used in injector cleaning by the industry it would be interesting to share the info
Faztbullet
Still not a DIY at home project...how ya going to get yer 40V to fire injector and the fuel return?????? Seen your old Telco so you know what 1A2 and Terryphone are..ex ITT myself.
Crosbyman
40 volts can be had and me I would just plug the OUT fuel pressurize the IN fuel with carb cleaner and fire away ..its up to him. Im out I rmc
​to us Telephone types (private services) a 1A set was a signal test set for basic operational testing of circuit E&M functions over carriers terryphone ?? nope never heard of it...... this stuff now rests with dodo birds
