Hi<br /><br />I've got a 1989 Evinrude 40hp VRO which looks like it has the CD2 unregulated 4amp alternator.<br /><br />I'm rewiring the boat with two batteries via a Perko battery selector switch with the field disconnect contacts (in case it gets switched off while th engine's running).<br /><br />As there is no regulator, do I need to bother with the field disconnect ? If the battery was disconnected at either high or low engine revs, would there be a volatge spike that could damage the other electrics ?<br /><br />Thanks for all the help I've had in the past through this excellent forum.....<br /><br />Paul
