Filler neck Mercruiser 1985 470
Ed_Green Bay
I need to replace the filler neck for coolant on the coolant resevoir on an 1985 Mercruiser 470.
How do I get the broken one out? Is it brazed in?
When I replace with a new one, do I braze it in or can I epoxy it?
NO YOU CANT @#$%@#%@#$%$% EPOXY IT IN
yes, it is brazed in
super easy repair for anyone in the radiator/heat exchanger repair business
since you are in green bay - take your heat exchanger to Mike at Valley Radiator, tell him I sent you.
If you need aluminum welding, Mike is your guy
if you need engine work, Stop in and talk to Larry at Baril Engine next door to Mike.
and if you need your starter or alternator looked at, go to Green Bay Rebuilders on velp
stonyloam
Scott, I think he is talking about the filler neck in the reservoir, not the exchanger. I think the reservoir is cast iron (not sure) so don’t think it is brazed in. I think it is a press fit with an “O” ring and held in place by the overflow fitting. If I were to guess (and it is only a guess) you would remove the overflow fitting, pry the old neck out, replace the O ring and tap the new one in place, secure it with the fitting. 23-26 here https://www.mercruiserparts.com/bam/.../30895/908/100
stonyloam
The only thing the manual says is “if the reservoir requires replacing, transfer the parts from the old one”, so it sounds like the filler neck should pop out after you remove the overflow fitting.
Bt Doctur
Most are copper or brass.heat exchangers The necks are mostly soldered in place on the copper heat exchangers so trying to pry it out will destroy it.All the 470 res I`ve replaced had the filler neck already on it.
remove the o-ring, braze in the new then.
either way, you cant epoxy it in place.
and if the OP takes it to Mike, the bill will be under $35
stonyloam
I don’t think so. The O ring appears to go under the brass piece. You can’t braze brass without melting it. I still believe it is a press fit that seals on the O ring. Yeah order the new piece and take it someplace, they will know what to do with it. Remember we are talking 470 here LOL! Remember to order a new reservoir to exhaust manifold gasket too. You will need to find out if you have an aluminum or iron exhaust manifold to get the correct gasket.
You can’t braze brass without melting it./QUOTE]
ROLTFLOL
I guess the million or so brazed heat exchangers that were manufactured with brass filler necks just during my short stint in the industry shouldnt have been able to be made then.
They braze brass and copper every day. And if you have the SN from the HX, the manufacturer can tell you who brazed it, and exactly what time it was brazed
stonyloam
I hear you. you are not hearing me
I also know that the standard filler neck that you show is pressed in on the 470, and when that continues to leak, you can also braze it to the reservoir, move on and go boating. it is also the exact same component that is also brazed in on most heat exchangers.
that little stamped part is about $1 (unless you get it thru mercruiser) then it is $28
stonyloam
OK I see, just thinking it is a lot easier to just pop the old one out rather than draining the system and taking the whole thing apart and replacing gaskets.
