Re: filling in some minor cracks on a fiberglass skiff
what kind of wax would you use?
None
This should be posted in the Resto forums..
Spider cracks are kinda a common term used.. just looking at them can tell you alot.
1. If the cracks look like rings/circles around a central point then its Impact.
2. If the cracks look like an astricks * ..then its damage is coming from the inside out ( look for pressure from the inside like a screw or something ).
3. If cracks are multiple parallel then It could be from bulkheads or stringer hard points.
4. If the cracks are from fasteners ( cleats, snaps etc ) .. then there coming from those drill points.
So.. depending on the Way the cracks are formed will determine the proper repair schedule...
Pics ?
YD.
PS. post them in the resto forum and have others help out as well
