ssmith32256
- Joined
- Sep 12, 2009
- 31
I have an omc sx outdrive that i need to put outdrive fluid in. I cannot get the lower plug out at all. I know that I am supposed to fill the lower unit from the bottom until it fills up to the overflow port bu the shifter cable, then fill the upper unit thru the cap on the top of the drive. Here is my question, if I CANNOT get the bottom cap out can I fill the entire unit from the top. I realize I will have to fill it very slowly allowing the fluid to get down thru the drive and fill all air voids. assuming I do that is it possible to fill it entirely from the top ? If this is possible should I run the outdrive slowly for a minute or two after filling and then attempt to "top it off " incase any air voids existed ?
