MickLovin
- Joined
- Feb 18, 2013
- 822
Hi guys, I can't see in my manual how it says to fill my tilt trim motor, I was under the impression you fill it when the motor is tilted up, but after reading a thread about a problem with a tilt trim, Jerryjerry advised that it is to be done lowered
, can anyone tell me which is the best way to fill, at the moment I fill in the up position and drop it down and up a few times and then check if it needs topping up, if it runs out of the hole I tend to think it is full, but in saying all that I had a slight problem trying to tilt in the water, it was fine at the ramp etc, it was just not tilting up when I was running, I had to slow tilt up then go again, but the motor drops a bit. I have a kit for it but I see no leaks.
