I have a Volvo Penta 200 (chevy) with a water separator and a glass inline filter before the pump (the filters are operating in a vacuum). Has anyone had better luck putting these filters before or after the pump? Mine is a cam driven diaphram type. The reason I ask is that it would appear that the sealing rubber on the water outlet at the bottom of the separator bowl would work better while the filter is pressurized rather than under a vacuum. I'm having a starvation problem that I may have solved when I found a small piece of Form-a-gasket that had swollen to the size of an asprin. I think this was gettin caught in the shut-off valve at the tank outlet. But while I'm working on the boat, I wondered if it would be a good time to re-do the plumbing.<br /><br />Anybody have this before?<br /><br />Thanks
