convergent
- Joined
- May 17, 2010
- 385
I finally hit something with my prop... actually two things kind of... yesterday. When we went into the lake, they had a sign up saying that the water level was down so be careful. I launched on one ramp with no problem. This lake is small and there aren't really too many places the water level is low after you get 10' from shore, except in the coves.
First thing I did was get the ski harness wrapped around the prop unknowingly. When I started the motor and tried to pull off, we didn't go anywhere, so I turned if off and fixed the rope. It didn't cut the rope or anything, so not sure how that worked. Does that mean the prop spun on the hub?
After we were done skiing and wakeboarding, I did a lap around the lake and noticed that I wasn't getting up to the same speed I usually do, and the RPMs were lower at WOT. I did have more people in the boat than normal... specifically an extra 225 pound guy. I will check again with the normal load to see if that was it, but it seemed odd. If the prop spun on the hub, is that something that has to be repaired afterwards, or is that just a passive failsafe kind of thing?
Then when I was retrieving the boat, I came gliding up to the trailer and hit something, and then immediately trimmed up. I was moving at idle speed, so pretty slow. When I got the boat on the trailer, I noticed the edges of the prop are dinged up. The prop was replaced a couple months ago so it looked new before. Nothing bent, just could tell the edges of the blades had the paint gone and were a tad rough.
How does this happen? If the skeg is sticking down way below the prop, how in the world does the prop hit the bottom? I don't know what is down there, but I don't think the ramp extends as far out as I hit something. I was probably still 50' from the end of the trailer when I hit.
