Finding parts for a Dynamark 11-36
Nandy
Today i went looking for the belt and blades for this mower. Boy, was it a long search. Went to harbor freight and the part guy has been suspended so no much help there. I do not hoave the original belt so I had to use a rope to get an idea. It is around 68 to 70 inches long. The guy at NT looked but was no able to find anything. He could not tell me when will they have a part guy again. No luck with the blades again, they are about 18 inches.
Went to lowes. They at least have all of their belts and blades in the floor so I spend some time trying to match a belt to my rope. After a few close calls I had ran all of their belts and no help. The blades were not find again.
Stopped at autozone and they found me a couple. I settle for the smallest one and move one of the pulleys to a different hole. But in my opinion, the belt is not loose enough for when you "disconnect" the deck pulleys from the motor pulley and when I use the level to activate the spring that put preassure it dont look like it does enough. I guess for now all I can do is put the blades and see.
The deck can also be raised and lowered to changed the level of the cut. But by looking at it it gives me the impression the belt is in such an angle it will come off...
If anyone has this mower I will appreciate it much if you can share where you buy parts for it, specially the belt and blades I did not ask for the blades. I might also try napa if any of the autozone belts dont work.
I still have to go to TSC to check both. ACE says they dont work the belts for it but i did not ask for the blades.
Initial post and pictures are in:
http://forums.iboats.com/showthread.php?p=2212422&posted=1#post2212422
Gary H NC
Re: Finding parts for a Dynamark 11-36
Tractor supply in Monroe Nandy. Its on the left just before 601.
They carry way more belts and blades than any other places i have checked.
We used to have an old yellow no name mower but was always able to get parts for it there.Belts,pulleys and blades were no problem.
Nandy
I got a belt from autozone but I am not sure it is the right size. I called Denver tsc today and asked for their riding mower expert. This guy was pitiful. I will still go, I can check it myself. Right now my biggest issue is when the blades are not engaged for the motor pulley not to worn out the belt. I know there is supposed to be some looseness in the belt when the blades are not engaged but it looks as if I get it loose enough to where I feel the motor pulley wont worn out the deck belt I will test it tomorrow or Sunday. I hate to wear the belt and not being able to return it.
dolluper
Model has side discharge ....grass that is not operator
Drive belt 1/2 X 82 part 54758
deck 5/8 X 71 part 43066
No blade info
Rear discharge phew
Drive 1/2 X 87 part 39454
deck 5/8 X 83 part 54738
blades 2 either part 32986 or 484044 Noma
The blade part numbers may not be good as
2 others came up also they are
49878 or 6235 check them out online
u know the sites with pictures
speedwrench
Try cheapmowerparts.com! They have the belt sizes (length) listed
Dave
Nandy
Thanks guys, I will check it...
