finding serial and model Numbers
plztellme
I have a 1990 50 h.p. force motor, but can't find serial or model numbers. There was a sticky on the motor, but doesn't reveal any info.:confused:
jerryjerry05
Re: finding serial and model Numbers
Those years they use stickers that quickly faded or fell off.
What are you looking for?Parts or service?
A little more info will help.J
roscoe
Knowing it is a 1990 is 99% of the problem.
Serial number is not needed.
And almost every part is interchangeable from model to model.
Now, if you are trying to register and title it in one of the 3 states that do these things, things get a little sticky.
And since you are new to this, did anyone tell you that you need to add TCW3 oil to the gas when you fill up?
If you don't, you will blow up the motor.
Add 2.6 ounces of oil for every gallon of gas you put in.
gus-gus
I am having the same trouble with my Merc 150. Dang numbers are sure elusive.
jerryjerry05
On the Merc the #s are on a silver freeze plug on the motor somewhere.J
plztellme
Thanks to all who responded. There are many things that I'll have to learn, for now I know that this forum will help.
hypersniper
Banned
i cant seem to find a freeze plug anywhere on my motor at all. i have a tag but i cant read the numbers
jerryjerry05
If your real desperate,under the back cover(Force) of the mid section.There is a casting stamp on the exhaust housing that will give the year and month it was made in.
Not positive but the Mercs have the silver plug on the right side as you look at the rear of the motor towards the bottom.
