libellav15
- Joined
- Jul 3, 2010
- 177
Hi all
Engine details:- 1972, Mercruiser 120, GM in Line 4.
story so far....i have established that the balancer has slipped slightly and the timing notch is now miles out from the timing mark range on the block.
if i get the mark anywhere near retarded enough to the 6 deg btdc mark with the timing light it stalls.
i can get the engine running fairly sweetly by ear/feel but i want to get it spot on to eliminate any bogging, pinking etc etc
so i need to get a new mark made at TDC on the balancer to get the timing right.
i have set up a local ignition switch to jump the engine round but its far too jerky to set up the precise tdc of compression stroke on pot 1.
i took all the plugs out thinking i could turn the engine with a wrench as you would with a car - but the balancer is behind the engine mount and the other option above it has 3 bolt heads in a triangle.
any tips/tricks advice on finding the precise tdc would be greatly appreciated please.
i have also read on a post somewhere that getting the dwell on the points spot on will automatically mean the timing is correct - is that true? i can't get my head around the relation between the two..
cheers guys
adam
cheers guys
adam
