Finding the model fishman outboard
I recently got my father's 1976 (I believe) evinrude fishman outboard. It needs a pump, but I can't figure out which model it is?
It does have a serial number plate with the number. When I search the number I don't come up with anything.
How do I find it? Something simple I'm overlooking?
Thank you for any help
Fuel pump or water pump.?-----Both are the same for many , many years !
lindy46
You need the model number. It will be on the ID plate. If it's a 6hp, impeller will be part #434424 or Sierra 18-3001.
They ( CD and Fisherman ) all used the same impeller from about 1955 to 1978.----Then in the last year they used a different impeller and housing.----Now that newer 1979 set up can be fitted on a 1955 model.----So take it apart and see what is in there today !
