Fireing order problems (help needed)
VISH136
I Have a problem i replaced the head gasket on my 1998 volvo penta 4.3 l gl vortec motor. I did not mark the distributor when i took it out which was stupid of me . Now i am having a hell of a problem figuring out the firing order.
Can anyone shead some light on how i go about finding the firing order and if i am looking at the motor the cylinder numbers on each side also how it corrispond to the distributor cap. Thanks
Very confused.
Re: Fireing order problems (help needed)
Ayuh,... There's the Manual for your motor up in the Adults Only section of this forum,...
In it, I believe it's explained how to set #1, at TDC,+ where the wires go from there...
zbnutcase
Firing order is 165432. 'nutcase
VISH136
Thanks Guys i found everthing i needed in the Adult section.
thanks
