Re: Firewire DSL what is it
The 384 and 192kbps represent your download and upload speeds respectively.<br /><br />The second, and more expensive package, has a download speed of 768, and and upload speed of 384.<br /><br />If the distance between your modem, and the isp's modem, is more than 18,000 feet (3.3 miles), the signal degrades.<br /><br />Both of these systems are pretty much on the low end as far as DSL. Many places are offering downloads of 1500kbps (1.5Mbps)<br /><br />Most is not all dsl modems that I have seen, connect with a usb or ethernet connection.<br /><br />Actual speed are very dependent on the quality of the connection and your isp's equipment.<br /><br />Your dialup may connect at 44k or 56k, but it likely transfers data at about half that speed.<br /><br />Here is a link to some DSL info.<br />
http://computer.howstuffworks.com/dsl.htm <br /><br />Also, I doubt you will get 4-5 times the speed out of the accellerator package. And it only really works if you visit the same sites repeatedly. It works by anticipating what your next move will be, based on previouse visits to the site, and then retrieving it to your isp, so when you actually do click that link, the info only has to download from your isp.<br /><br />I would see if they will guarrantee the download speeds, and allow you to cancel the deal if it doesn't perform.
