Firing Order
Kirkman24
I have an Crysler Skier 700, Model# 709H9A Serial # 4366, I was wondering if anyone knew the firing order, it is a 3-cylinder rotor cap, stupid me forgot to label first. Thank You for anyone's help.<br /><br /><br />Kirkman
OBJ
Re: Firing Order
Welcome Kirkman!<br /><br />I'm taking for granted that this is a three cylinder? The model number you posted doesn't show up in the model guide anywhere. Would it be 70973? This would be a 1979. If the plate on the transom bracket is messed up, look on the block for a large welch plug. The model and serial number will be there also.<br /><br />Back to the "timing". If the coils are stacked next to the cylinders, just run the spark plug leads to the corresponding cylinder. Top coil > top cylinder, middle coil > middle cylinder, bottom coil > bottom cylinder.
OBJ
Re: Firing Order
Hmmmmmmm.....my reference book only lists 70973....the web page list's 70973/70979 as 1979.<br /><br />Thanks ob.... :)
Kirkman24
Re: Firing Order
Yes it is a 3-cylinder and I am sure it is a 1979...Thank you for your help
OBJ
Re: Firing Order
OK Kirkman.....hope we got ya' straight on it.....even if we get confused on model numbers....... :D
Kirkman24
Re: Firing Order
Actually it has a cap with 3 spark wires coming out. Would anyone know where each wire comes to each plug? Thanks again
ob
Re: Firing Order
We must have our lines crossed somewhere on the year model.A 79' 70 hp engine doesn't have a cap or rotor to check,but a powerpack,timer base, and three individual coils.
Kirkman24
Re: Firing Order
OK maybe this will help....It is a Crysler Skier 700. Model # 709H9A Serial # 4366. It has 3 cylinders and says 70hp on the tag on motor. I am new to boats so I might really have confused a bunch of you....I am truly sorry. Aagin Thanks for any help?<br /><br />Kirkman24
Kirkman24
Re: Firing Order
Also it has a rotor cap with 3 spark plug wires coming out, I need the firing order for that. Again sorry for confusing you......<br /><br />Kirkman24
Mod2
Re: Firing Order
We'll move your post over to the Chrysler/Force repair forum Kirkman. This is where you should have posted. It happens..... :)
