Yamahahaha
- Joined
- Dec 24, 2011
- 18
Hi: Recently cleaned out the water jackets etc in my 1986 V6 Yam 200HP 2 stroke. Put it back together and tested it in the tub and all seemed ok. I put her in the water for a test run and she was working ok. Had her in midrange just up on the plane when a non-related incident in the deck area caused me to pull the remote control quickly back into neutral ? This is supposed to also bring back the throttle to idle speed ? NOT SO! Something must have jammed up and the motor ?ran away? howling for 5-10 seconds before I could pull the kill switch. Still not sure what happened there but got her running (Sort of) ? Was able to get her up a little on the plane but she would not get up to full throttle and kept losing power. Got back to the dock and she died. There was a lot of unburned fuel mix coming from the leg and scumming the water. (I prefer to use the 50:1 premix rather than the oil pump.)
I took her home and set up the flush tub - Checked compression and found to be excellent: 118 across all 6 cylinders with virtually no variation. ? This brings me to the current situation:
Started the motor and it appeared to be misfiring so I replaced all the plugs and checked the gaps. Also checked to make sure all the spark plug lines were firing by sparking them across to the head bolts. Cleaned the fuel lines and filters and used new fuel mix.
Started the motor again ? plenty of smoke and running sluggish. I pulled the bottom plug from the port head of the V6 ? No change in the running. I left the plug out then pulled the middle plug ? Still no change!!! ? I pulled the 3rd plug from the port head and STILL NO CHANGE!!??
I replaced all 3 plugs then pulled the bottom plug from the starboard head and there was an immediate drop in power. I left that plug out and pulled the middle plug ? Only a very minor change (If any) I replaced the middle plug then pulled the top plug ? The engine stopped even though there were only the 2 plugs not being used. It appears the motor was running only on 2 and a bit cylinders!!!!
Observations: Lots of unburned fuel mix still coming from the leg;
A fair amount of smoke coming from the twin water/exhaust vents at the top of the upper leg;
Water streams all seemed ok; a minor amount of smoke coming from the spark plug hole in the port head when plug is removed.
Because at least 2 of the 6 cylinders were firing I would think the problem would not be with the reed valves ? I believe, if the reed valves were the problem they would result in all 6 cylinders going out of action ? I COULD BE WRONG SO PLEASE TELL ME IF I AM.
MY THOUGHTS FOR CONSIDERATION: Could it be that the ?run-away? incident on the water caused the timing to go out of sync?
Other than this I am at a loss to figure this out ? IS THERE ANYONE OUT THERE WHO CAN EXPLAIN THIS? This is more Funny peculiar than funny Yamahahaha!!?? Cheers, Yamahahaha, Wollongong, NSW, Australia.
