First and Last day of 2003 boating season
TwoBallScrewBall
Hi all.<br /><br />Been boating all my life but just got my first boat. Up the street from me was for sale a 1988 Bayliner 1950 capri. "Runs Excellent" it says on the windshield. So I go look at it, vinyl is in bad shape up front but other than that it's looking good for an '88. Floor is solid, no cracks in glass, etc. So we start up the 3.0 I/O and it cranks right over and runs fine. I picked it up with the trailer for $1200. <br /><br />The heat exchanger for the closed loop cooling system leaked so i fixed it with some JB weld. I also had doubts about the impeller since when we test ran it there was no water, but I am seeing flow coming from the hose going to the mainfold so I figure it's fine.<br /><br />This Saturday was the maiden voyage. I drag it over to a local marina and drop it in no problem. Tie it up and let it idle for a while, seems OK so I head out up the creek. I get about 1000 feet and the temp is at 250 so I turn around and head back. 2 hours later I have a new impeller and water pump housing installed and am back in the water. A friend of mine shows up with his girl and comes along, so now it's the four of us including my wife. We start out again and now the temp is staying right at 160-180. Nice. <br /><br />We idle out through the creek no wake zone and it seems great. A few little gooses of the throttle show that the engine responds well. So we finally clear the no wake zone and I give it about 1/2 throttle to plane out. I'm hearing this slight knocking noise now. My brain is saying "rod knock, better go back in" but my hands are saying "first day out, already September, lets go". Everyone on board agrees. So I give it full throttle. There was not much of a difference in power going from 1/2 to full so I am getting more worried now. Still running along good though. Then the not-so-loud knock quickly and violently turns into the loudest most horrible engine noise I've ever heard. I throttle back and it's running rough now. Yup, the rod snapped. Time to head back. So we swing around and start putting back to the dock. Engine bay is still dry at this point. About 1/2 way in at 1500 rpm or so I decide to give it just a little more gas, and immediately hear something go "BANG KA CHING CLANG CLANG BANG" in the engine. Now she's really shaking. I mean bad, the side windows I was sure were going to just fall out. I set the throttle to hold just about 1200 rpm and make it back into the creek. <br /><br />At this point the engine temp is rising quick, so I'm sure I've punctured a water jacket or something, and the ehgine bay is starting to smoke. I take a quick look and there is oil everywhere. I mean everywhere. And I see some green swirlies in the mix as I suspected. Now the temp guage is at 250+ and the engine dies, we're floating in the channel. My buddy grabs the paddle and starts moving us along at about 0.5MPH. <br /><br />I wait about 5 minutes and try again, the engine roars to life. I slam her into forward and we continue along, a bit faster than we should be but still under 10mph. Any slower and she starts shaking and we're only about 1/4 mile from the ramp so I just want to make it back. At this point this little 4 cylinder is rumbling like a big block, and smoking like no engine should ever smoke. We make it back to the dock, I kill the engine about 200 feet out and drift up to the dock for fear that all this smoking oil and the off-the-guage engine temp will spark a huge fire. We make it back. I pull the boat and have a better look. There is a 4" wide hole on the port side of the block at the #4 journal. Peeking in the hole I can see the gauged-up crank journal, no rod, end cap or bearing anywhere to be found. <br /><br />The good news is that the boat didn't catch fire, floats, and the outdrive still works. Bad news is I now have a new winter project, find and replace the 3.0. <br /><br />Not so much a stupid human trick, but I figured this was the best place for the story. <br /><br />Check out these links for the pics of the aftermath:<br /><br />
<br /><br />
jasonballard
Re: First and Last day of 2003 boating season
"Buyers beware"...always test drive before you buy, take it to the lake.
chuckybaby
Sorry to hear the bad news ! Had to laugh tho. When my 200 blew up my brain did essentially the same thing <br />...<br />Pull into the marina for lunch...everything ok. return to boat, start her up and hear knocking.<br />Righ brain says "sounds like something is loose inside the cover, must be hitting the flywheel"...left brain says "you know a death rattle when you hear it, shut the **** thing off, quick". The left side was right.<br /> <br />I have several pieces of piston and casing that I keep in plain sight on the kitchen windowsill to remind me to usae only OMC oil in the new block.
Spidybot
Sorry to hear about your misfortune.<br /><br />Impressing that you're able to describe this as if it had been a normal, everyday happening like 'Hey, Honey, I broke one of these old glasses'.<br /><br />Good luck hunting a suitable replacement!
neumanns
Yep, Its due for replacment. ;) Since this started out not as a project boat and you have had it out boy will you have a bad case of the boating blues by time season rolls around again. Good Luck!
TwoBallScrewBall
Hi all,<br /><br />I have found a long block for $1590 ahipped to my door (would have been $1140 if I had a usable core!). Probably going to go with this. <br /><br />It did kinda start out as a project boat. The interior needed refinishing, and I was going to spend the winter doing that and just cleaning it up. Now I ahve a new item for the list, that's all! I'll still have a good running boat with trailer for less than $3000 when I'm done, and I'll know the engine was well taken care of from day 1 now. Gotta look at the bright side. Of course in the spring I'll drop it inthe water and the outdrive will fall off with my luck. In which case I'll just tie my neck to it and go down with it! :) <br /><br />Anyone have any sources for OMC rebuilts, preferrably in the NYC tri state area?
TwoBallScrewBall
Just got around to hoisting out the engine today. I was very suprised to find, in the bilge under the engine, a full connecting rod, complete with piston pin. The rod is bent at about a 45 degree angle 1/2 way up the rod, and the ears for the cap are gone. But the pin is in perfect shape! ;) The rod must have ejected through the hole pictured above. No wonder it was so **** noisy!<br /><br />Still weighing my options on the replacement engine. I think I will only be keeping this rig for a couple years, but I definitely want to get it running for spring so it's looking like it's going to get a rebuilt 3.0 long block with a warranty. Luckily for me the outdrive is in good working condition. <br /><br />Here's to winter projects! :) <br /><br />Later,
SoulWinner
I wish you many blessings with this project. I hope all goes well when the boat is back in the H2O :)
