First boat purchase. Help!
Tnstratofam
Look for any water in the ski locker or bilge. Any soft spots in the deck are a deal breaker. Look for faded interior pieces or cracked vinyl as this can indicate the boat was stored outside uncovered. Look in the engine compartment for signs of oil or power steering fluid leaks. Look at the underside of the motor cover/doghouse, and any seat bottoms that are accessible for signs of wet or rotting wood. This also can be an indication of poor care by a previous owner. I'm not familiar with the performance of the 3.0 mercruiser, but I think it may be under powered for a ski boat. It will probably be fine for cruising, but don't expect it to be a hot rod on the water. If it's in good shape mechanically and structurally the current owner should be willing to meet you at a lake to do a sea trial. Do not by it without one. In the end even if all those things check out, I would only offer $2500.00 and only actually pay $3000.00 for it. Remember boats don't appreciate in value based on age like classic cars do. Also ask about service records. A good owner will have records and receipts .
Just my opinion with a rotten glass ski boat in my garage to influence my opinion.
Good luck.
lebou1sa
Thanks for the help! I also plan on looking at a 92' 190 Horizion that has under 200 hours on it for $6500 so hopefully one of the two will be able to come home with me :)
milehighjc
Look carefully at the checklist pinned to the top of this forum. I used it, was VERY helpful.
cptrick3
At 200 hours it spend years just sitting around somewhere. Who ever bought that new probably put on that 200 hours in the first year or two. At least have a marine mechanic check out the engine/outdrive.
lebou1sa
I will definitely do that. It was owned by an elderly couple who live on a lake. From what I understand they mainly used it when the grandkids came up and recently bought a new boat.
jkust
Pictures are so often deceiving but that looks like a well maintained boat in these pictures. The teak looks like it is in really nice shape and they cared enough to re stripe it. I hope it is as nice as it looks. I'm not at all a fan of the 3.0 especially since back then, the HP was measured at the flywheel not the prop meaning it isn't a 140hp engine where it counts at the prop. It's a bullet proof engine though and if I were buying a modern boat, I wouldn't ever consider the 3.0 but back in those days a 3.0 was a lot of hp and so I'd shift my paradigm if I were buying something of that vintage. We certainly did a lot with much less hp in the 80's and were happy to have it. Plus Chris Craft had a bit of cache back then too and would be a nice boat for the fleet assuming it was as nice as it looks.
