So my winter project (try and get one every year) is a 96 Baha cruisers 260 cc. Like the hull design. Overall low end construction which is why I got it. Looking forward to the challenge of bringing it back to life better than before.
the entire deck is shot. So far I’ve gotten 80 percent of the old plywood scrap pieces removed and the bottom layer down to bare glass. there’s roughly a 2” perimeter to tab in around the hatches and side walls.
my plan is as follows. This is my first deck job so I’ve been researching different methods and materials.
I do not like how thin the bottom laminate is so my plan is to lay in a single layer of 1708 using epoxy resin.
Then since I’m using coosa board and it should be glassed on bottom (here is where I’m not sure) lay up a single layer of csm on the back.
set the glassed bottom coosa in with slightly thickened epoxy resin.
Fill gaps and gap under perimeter around with thickened poly resin
tab in with 1708 (poly)
two layers of 1708
fare it
gel coat
please stop me if I’m wrong here before I f it up! Thanks!
two layers of 1708
fare it
gel coat
