First launch for an untested engine.
scrit9mm
Took the aluminum 14' to the water yesterday. Had the motor running at the house so in theory it should run at the ramp. Well I back down the ramp a little too far and the wind takes the boat off the trailer. I couldnt winch it up because it would beach on the concrete ramp and I could not pull forward for the same reason. So I get wet and walk it to the beach and tie it off. I park the truck and head back down, looking to still salvage the day. I pull on the string and nothing! Of course now it is flooded. I wait... pull it more and nothing. So I go get the truck, walk the boat back to the trailer fighting the wind the whole time, trailer it to a parking spot. The plugs are soaking wet with fuel so I go home. Waisted day!
One thing I am proud of is the ramp was pretty busy and I never held anyone up due to my neglegence.
Next time I will start it in the parking lot!!
tpenfield
Re: First launch for an untested engine.
Sorry to hear about your tale of woe. . .
. . . It is always good to start the engine with ample water supply, so not sure if you can do that in the parking lot.
River_Lizard
I always bump mine in the prep area before launching, the second I hear it fire I switch it off. I just want to know that I'm not going to be the person blocking the ramp when my motor doesn't fire up.
scrit9mm
That is what I normally do with the Chris Craft, I should have continued this same procedure with this one.
Home Cookin'
while just a bump, literally, to see if the battery turns over is fine, running "until it fires" can fry your water pump impeller--it's tight dry rubber against metal in there.
bgc
Ensign
I had the same experience last year after rebuilding my old Mercury 500. I had run it in the tank for an excessive amount of time and took it to the river to do some breaking in...... Pulled so much I bloodied my hand, embarrassed and really ticked, I loaded up and went home.
I hope you find the cause of the no start and have a successful launch next trip.
SteveMcD
I test my engine before I hitch up while I can still muff it.
Pontoon24
I never crank a motor dry. If it's a small outboard a 5 gallon bucket is all you need.
coreybv
I cranked a motor dry ONCE. Later that day I was 5 minutes out from the ramp and overheating. Had to replace the head gasket and have the head planed. Never again. Now I get nervous about even having the key in the ignition if the muffs aren't on.
When my old Merc 140 was having issues I got in the habit of running it on the muffs at home before heading to the lake. Being fortunate enough to only be a 15 minute drive from the ramp the engine was still nice and warmed up when I launched. Fortunately I got the starting problem resolved before I started renting a slip.
