Re: First look inside my Alpha One
Do you know how the water got into the bellows? Just tore mine apart yesterday, I didnt have what you had in your picture but there was a little watter in the bottom. Hope you get it going.
Glad you asked. I had the engine replaced after one of the marine shops here put a new head on. I had to replace the engine because about 10 minutes of running with the new head, the old engine locked up.
So I bought a new engine and had the same morons put it in. Got it out on the lake and my boat was swamped as if I hadn't put the plug in. It got pretty deep back there. Was able to get the water out by running the bilge pump. Sure wish I had one of those pumps with a float on it. I suspect that is when water got into the bellows.
Once the water was out, I still couldn't find where all that water had come from that swamped the boat. When I started it up, water was flowing out of the thermostat housing like Niagra Falls. The moron mechanics at Eastside Marine here in Springfield Illinois had not put a thermostat in. The bolts weren't even finger tight.
Shortly there after the new starter was dead from being swamped I'm sure. I also had to replace the head gasket on the new engine. I may be wrong, but I suspect the head blew because I was running the engine too cold.
This is why I'm wanting to learn how to be a marine mechanic. I can't believe the money I have paid these idiots around here. I want to learn it all myself so I can charge big bucks to do things right the first time.
