Hey guys, new to the forum and have been reading around a LOT. This is an awesome community. Im working on a near mint condition 1982 19 ft Ski Centurion. Its PCM351 powered w/ 200 hrs on it, all interior and exterior is in mint condition
The only only thing wrong with it is that the stringers are totally shot:facepalm:
I have been reading tons on stringer replacements and feel fairly confident in the whole process when starting from a bare hull, tabbing them in, and then glassing the whole thing.
My question is...
After cutting the top out of the stringer and removing the crud inside, Its pretty well cleaned up and we are left with a GOOD fiberglass casing with a hollow top of where the stringers used to be. Is it possible to just bed the stringer inside of this instead of hacking them off and starting at bare hull?
The internal dimensions of the glass casing left are about 5.5" deep, 2" wide the length of it, with a 3" wide sistered section where the engine/trans mounts midship as its direct drive. With these dimensions its possible to prep the inside of the glass.
One of my older, sea-knowledgeable friends stopped by and we were thinking of rough and scuffing the entire inside of the fiberglass casing. Using 2 layers of 3/4" marine ply laminated as the stringer with a 3rd layer at the engine mounts. Bedding this inside the original fiberglass casing with the PL Premium adhesive. Then filling the 1/4" gaps on the side with a thinner peanut butter to avoid air gaps. The cap the stringer and run a layer of 1708 over it all. Would this work? Seems like a lot less work than starting bare. If I need to I will gut it all, but trying to avoid that.
Any suggestions are greatly welcomed! Im a newb so dont be gentle, Im here to learn
My question is...
