steve_h7
- Joined
- Sep 16, 2018
- 401
This is probably a question I should know the answer... I'm rebuilding an '89 Campion Allante
185; floor and stringers are mush. I was hoping things would get better towards the transom
but I'm obviously not one of the 1%.
I'm assuming since the stringers are bad up to the
transom, and the transom is very wet (but no actual rot visible like the floor and stringers)
I should still replace it?
My question is, if so, there's a well in the stern that I'm not sure what the proper name is
but it's part of the cap and butts up against the transom so I need to do something with it.
I REALLY don't want to try and remove the cap since this is my first rebuild and it might put
the project's complexity beyond what I can do, Is it possible to cut the well out of the way
and then maybe glass it back in place after the repair? Or?
I'm open to possible options that my beginner status can accomplish! I'll attach some pics that
show what it looks like: #1 is the rotten stringer and transom, #2 shows the well that needs to
be moved,whatever it's called.
Thanks in advance!
Thanks in advance!
