Leviathan
- Joined
- Jul 6, 2009
- 38
I got an 89 Capri with the L-Drive 3 cylinder 2 cycle from a friend that needed a few repairs with the carpeting and other upholstery.
I ran the boat for a little bit with the prop submersed in a container of water. It seemed to idle fine and everything, when I would throttle it up it started to smoke, then on deceleration it sounded like it was rattling or something was loose. Afterwards it smelled hot so I let it sit, but fired it up again to be sure it was still OK.
Today I put it in the lake for the first time. After cranking it for 15-30 seconds it started up and sounded pretty good. It was misfiring a bit, but I assumed it was just cold so I let it warm up a bit - maybe 2-3 minutes and started out on the lake. I was able to give it full to half throttle for about a minute or so before it shut down - smelling hot once again. So I pulled the plugs to see if they were fouled or anything and this is what I found:
Even though the picture doesn't really do it justice, the plug is covered in silver deposits. It appears that cylinder number two was seeing some detonation and probably burned down. After a compression test I'm going to be looking to rebuild this thing. I know there isn't much out there for parts but I was hoping you guys would have an idea as where to start looking.
Thanks,
Aaron
Thanks,
Aaron
