joshackley
- Joined
- Apr 10, 2013
- 38
First time boat owner, as the title says. Been around boats in and out, can operate them, but know next to nothing about maintenance, care, wiring, or the motor. I am having trouble locating the correct manuals. The motor is a 1991 Force 70 HP, model 708F91C. So if someone could direct me to the correct manuals I need for this motor, that would be a great help.
It has not been run since last summer, and I suspect was not winterized. Prior owners have replaced the built in fuel tank with a portable tank. The motor does start with a little bit of work, will idle, and will (with limited throttle) run in the water. The motor runs okay in neutral and in idle, although it doesn't seem to be running like I think it should. Forward and reverse gears work and are not hard changes. Prior owner says the carb and water pump were done last summer.
Issues I have with the boat.
1. The tach does not work.
2. Motor bogs down and starts to quickly die at somewhere between 1/2 and full throttle. If you quickly put it into neutral it will idle and will not die. If you do not, it will die.
3. Throttle in forward has to be pushed from vertical to almost horizontal before any increase in RPM's.
The prior owner gave me some gaskets for the carb. But I really have no idea where to start, what to do, how to do it, etc, so all help would be greatly appreciated. Also, I've read about flush valves, ear muffs, and using a trash can to test at home. Can someone provide some insight for this motor?
Thanks in advance. I hope I've provided enough information for you to help me.
