I just purchased my first boat and it has a older Mercury 402 2 stroke 2 cylinder. Not sure of the year but the serial is 3727480. I couldn't figure out those websites that help you decipher your year by S/N.
I took it out for the first time to see how it ran. All was good at first. After having it at wide open throttle for about 10 minutes it started smoking on me and shut down. It would not start back up. I trolled around and fished for about 15 minutes and it started up then. However, it was running very sluggishly. It would drop speed and attempt to speed up on it own. It would fail to speed up for more than a few seconds at a time though. The engine kept bogging down. My buddy was out with me and he suggested I start off with simple things like spark plugs. The plugs in the boat are Autolite 2852. Any idea if these are the right plugs for that engine? I'd like to throw in some NGKs but do not want to cross reference the ones in there now in case they are not the right ones.
Anything else to look at based on the basic problems I gave? The fuel lines and primer bulb are new. Tank is new. Fuel is properly mixed 50:1. Throttle cable is new.
Thanks in advance
Sam
Thanks in advance
Sam
