convergent
- Joined
- May 17, 2010
- 385
I was dropping off my boat to have a seat repaired and the guy there said my bearings didn't sound right as I rolled past him. It was on my list to deal with, but just went to the top (only had the boat for a few weeks and usually only trailer it about 1 mile to the ramp). I'm pretty mechanically inclined but never tackled wheel bearings on a trailer before.
So I jacked it up and pulled one of the four hubs and started taking things apart and cleaning them. The seats on the spindle for the bearings look pretty good, but on the far inside where the seal rides, there is a very tiny groove there which you can kind of see in the picture... the shiny part closest to the painted part. Looking at that closely, it looks like that shiny part is a sleeve that will slide off, but I'm not sure. There is also a tiny hole on the bottom side of it, that I assume is for the grease to go into from the grease fitting on the outside of the hub.
So here are a couple of questions...
1. Does that sleeve come off, or is that part of the spindle? I don't see how it would be easy to replace the spindle and the tiny groove isn't that bad... but if I can replace it then I will.
2. If I can't replace that sleeve, is it OK to take some fine sand paper and smooth out that little groove... or is that even possible?
3. I haven't taken the races out of the hub, but they definitely need to be replaced. I don't want to mess them up so I'm wondering if I'm better off bringing the hub(s) into the parts store (finding one with a machine shop) and have them press them out? If its not that bad to get them out, how should I do it exactly? I am assuming a cold chisel and hammer is the way to go on this, but again don't want to end up making them impossible to remove if I mess up the lip of the race and then can't get it out.
4. When I put this back together, I know I need to pack the wheel bearings. Is it necessary to fill the whole inside of the hub with grease also, or just pack the bearings? Once its back together, there is a fitting on the front... how much grease do I put in?
5. Is there any value in installing bearing buddies? As I said, I have a fitting on the outside of the spindle to put in grease already.
