Re: First time startup, any suggestions?
Unlikely Pete, if the boat was covered in a garage then your chances of having gas that is at least salvageable increases. A thorough check of your carb float bowls should reveal whether or not a complete drain and cleaning of the system is warranted. Since the float bowls are the highest point in the fuel delivery system, and the contents of the bowls is limited a check of them will reveal pretty well just how varnished your fuel delivery system is. If the bowls are "clean" don't appear to have an accumulation of molassas looking material on the bottoms, and the needle jet ports are not fill with the same stuff, chances are good that the rest of the fuel system is free from the same varnish and adding as much fresh gas as possible prior to starting is advisable. I would not recommend any fuel additives at this time, wait until you have the engine running and have depleted much of the original fuel mixture. IE..bad gas and good gas.
