first trip in 600.00 toon starts hard after shut down
whiting-5
heres how the days events went
1.lauched boat starts right up ideles no problem go park truck and trailer
2.let idle at dock sounds great put in gear take off no problems
3.run about 1/2 throttle for 5-7 min.smooth as can be running
4.run her about 3/4 throttle for 10 min.still smooth as can be
5.bring her back down to idle let her run for 5 min. just kinda checkin the boat over. engine just dies.
6.try to restart cranks fine but has hard time starting like its flooded.finally starts raise the fast idle lever idle goes up a little for about 10 seconds then it revs up like crazy.sounds like it cleared itself out.
7.lower idle back down put in gear still idiling fine but try to give it some throttle just dies.
8.repeat step 6,7 about 5 times really have to play with throttle feathering it but finally takes off and runs perfect
9.repeat steps 6,7,8 everytime we shut it off
now i put new fuel tank,primer bulb,fuel lines,spark plugs,fuel filter.all before we put in water, and fresh gas. pulled carbs back off tonight when we got home and look perfect all jets open no debris in bowls all three look clean as can be.
just got me stumped as this is the first outboard i have ever owned always had i/os and jet boats.
1993 75 hp mariner 2 stroke
