The first trip ROYALLY SUCKED besides the fact that such an old boat was a head turner I can t say the same about the ride.
The motor started first key, idleing so so, at troling speed you can feel that the engine was out of breath, I couldn t go more than 8 - 10mph, as soonest I try WOT the engine was boging down and die ....not pleasant on Michigan lake and 30 feet away from the shore stone wall.
I can say I am dissapointed and I decide to scrap any trips for this year I will try to overhaul the piston rings .
The compression for both is ~100 +/- 5psi, now if I disconect the cyl #1 the RPM does not drop very much, if I disconnect #2 there is a significant drop in RPM, I checked the spark on the cyl #1 is nice and blue, sparl plugs are gaped and new J4C, after the trip they were wet with slightly oily residue.
I don t know why it was going so bad at WOT I suspect flood of the engine, the fuel pump and carburator are freshly rebuild, in the carburator kit came a spring for the needle but my old one did not have one so I did not installed it, another thing is I don t know where is the vent for the carburator so I don t know if is working or not.
Any opinions are welcome.
PS- Motor 1960 Johnson 40hp
