I have a 200 hummingbird. I has been having a few problems. It worked fine untill just the other day. Then when I turned it on it was set(reset itself) to metric and small numbers. It also did not show the water temp any longer. Along with this it now cuts out about every two seconds and leaves a blank strip on the screen and goes to 1 foot depth(which is the offset I have programmed into the unit). ANy idea what has happened?<br /><br />thanks<br />longshot
