fish finder stops reading, transducer dirty?
lewkster
I have an eagle fish finder( cheap model) Last year worked fine( new last year) It stops reading depth when under way. I believe it's mounted properly according to directions. My thought was does transducer get dirty and need cleaning maybe? Sugestions as to possible cause's welcomed.
D
DJ
Guest
Re: fish finder stops reading, transducer dirty?
Unlesss the boat sits in the water all of the time, the transducer should be fine.<br /><br />However, did it get moved? It doesn't take much to move one out of place.
eurolarva
Are you using a plastic clip on your transducer? I have an old eagle and was having the same problmes. On mine there is a plastic clip that locks down however when I put it on my trailer it unsnaps. Check to make sure it is tight
