Fish Finder
mcruea
Id Like To Mount My Transponder In The Hull For My Fish Finder, Has Any Body Done This Befor, What Type Of Apoxy Or Glue Would I Use, And How Good Does It Read Though The Hull, I Tried To Put It On The Back Of The Boat , But Its Not Reading Very Good Back There, Anybody Can Help Thanks:d
Texasmark
Re: Fish Finder
Lot's of archive stuff. Yes it can work just fine. But I question your comment that it currently doesn't work too good. If the signal is weak then it won't help. If interference is your problem then yes it will help. If you are having problems reading the depth at speed then yes it will help.
Mark
mandopickr
Re: Fish Finder
I just recently installed an inhull transducer (transom type) using many of the tips others on this site offered. Thanks to some of those tips, it had no reduction in sensitivity (depths at 100" or less, freshwater).
This is what I did:
I took my boat out to a cove where I was familiar with the bottom structure.
I hung the transducer over the side of the boat, and with my trolling motor, slowly went over several areas of structure. I then placed the transducer in a bag with water, and put it a various places in my hull, using a small bag of sand to keep it in place. Small variations in placement made a significant difference, but I was able to find a place where there appeared to be no loss in signal. By the way, I turned off the fishfinder (Humminbird 161) before handling the transducer.
I dried the hull, sanded the location lightly, and used ipa to clean the place. Using 50 ml of 50 min epoxy(from Walmart), I put down the epoxy (there was a small depression in my hull so I didn't have to make a dam), applied a small amount to the face of the transducer then gently pressed it into the epoxy. I weighted it down and let it sit for two days.
The results were better than I expected. I never loss the bottom up to 100 ft at 30 mph. Bottom detail, even at speed, was great.
Many had cautioned to experiment with the location in the boat. Now that I've done it, I think that is the key for a successful installation. Good luck.
mcruea
Re: Fish Finder
thanks for responding guys, the only problems i have trying test it for the best spot id have to tear every thing up , i cant see the bottom of the hull no where , the easyest spot would be where the gas or the batterys are , and id have to take them out to get to the hull , and i get to much interferance from the motor at high speed ,so i move it out futher from the motor and i just got 10 ft roster tail ,ill have try under the tank
