Fish Finders NAKED?
Stumpknocker
or do they come with the transducers and power cords ect? I was looking at a couple of units and the way the description reads.... maybe they ship you the goods, maybe you have to buy them "extra" under accessories..... I hardly consider the power/transducer cords accessories.<br /><br />Lowrance X126 specifically. :confused:
crab bait
Re: Fish Finders NAKED?
they pretty much come clothed..<br /><br />but the fishies on the screen ,, they are pretty much in birthday suits..
ThomWV
Many fish finders are sold without transducers, but I don't know of any that are sold without power cords and mounting hardware. I wasn't aware that Lowrance was packaging any of their units without a transducer though. <br /><br />For most of the better finders you'd find in the salt they are frequently sold without transducers. When you buy one this way it is then customarty to buy the transducer that best suits the use you will make of it. At the same time you can usually buy the same units with pre-packaged transducers from most of the major retailers. In that case you get what are the standard trasducers, though it might be in either an in-hull, thru-hull, or transom-mounted configuration. Most folks just go ahead and order the transducer from the same people they buy the fish finder from - sort of an a La Carte way to buy electronics. <br /><br />The thing is, if you have a rather narrow set of interest in how you use your fish finder then it might be worth the time to look into one of the high performance transducers. <br /><br />It might also suprise you to find out that you can actually work with the transducer manufacturer (I use the singular for good reason) to make a special transducer for your application. Just a couple of months ago a fellow on another message board got a couple of guys together to buy a single production run of in-hull transducers optomized for shallow water operation. The cost wasn't very much more than a standard transducer - I believe 3. guys had them made.<br /><br />There are also over the counter high performacne transducers you can buy. I have one that is optomized for deep water use. It made a big difference in how my fish finder worked. The major manufactur is a company called Airmar, the do their sales through a company called Gem Electronics. They make transducers suitable to Lowrance products (although Lowrance is one of the few fish finder makers that also makes their own transducers).<br /><br />Thom
Stumpknocker
Thanks for the info. I am not really all that savy when it comes to the transducers and their operation. I usually fish in 35-85 feet of salt water. Rarely go any deeper. I've used color and just don't really get it. I would much rather have higher resolution and a more moderate price. The X126 seems to be the ticket for my needs at least so far. Still looking around. I would like the trip/speed feature to work but I suppose that would have to be an optional unit that would have to be mounted elsewhere from the transducer.
crab bait
that's more/less the problem with most/all stuff.. <br /><br />there's a 100 different kinds.. a nary-o-one has the right 'bells' ya want..<br /><br />that's pretty much why i 'invent/morph/customize' most stuff i want/get..
Mr.Ladyfish
Make sure you get one with the "scrolling fish screen" otherwise it gets real boring watching it. :D
crab bait
yeah,, i'm workin' on a video cartriage that'll plug into the FF.. then i can play 'BASS-O-RAMA' on it when the bite slows down..
andymc
i own the x-125 i like it and would definately recomend the 126. it has a few more add on options than mine as well as better resolution if i had to do over again i would by the df version as it gives you the ability to view a wider or narrower cone. this comes in handy when trying to track downrigger balls. call lowrance thier suppurt staff is prety good at putting the tech junk into perspective for the "layman". i typically troll walleye & salmon in 12-200ft on lake ontario and this unit has made a difference in my ability to "locate" fish. check jollyannesales.com for the best prices
