Fishmaster 190 Gauge Cluster
mark32288
Recently purchased an 01 Fishmaster 190 that has an issue with the gauge cluster. The male connector behind the cluster seems to be the issue. Rather than having to take the entire cluster apart, is there an aftermarket option for the entire cluster?
Watermann
Most of us have gauges that are separate. You may have to pull them and see if the connector is able to be re-soldered to a board.
gm280
I concur with the above suggestion. And if you find out that the connector is properly soldered to the gauge cluster board and it is the plug with the problem, you can always solder the wires direct to the connector. It won't be easy to separate anymore, but it will solve the problem. JMHO
GA_Boater
What is the issue and what is wrong with the connector.
Unless you want to replace the whole thing, more info helps us help you.
