Re: Fitch Stalls
I also have a 90 HP Evinrude Fitch, but it is a 1999 model. It seems that after I've run it at higher speeds for a while and then go to idle around, like at a marina, it will "beep" and cut off. The idle at this time is rough and you have to be quick with the throttle after going in gear or it will cut off again. Does yours do this too?
