fitting 14 ft vhull flat bottom metal fishing boat on a 7 ft snowmobile trailer
brianis
so the delimna have a little snowmobile trailer that i use for a utility trailer guess i didnt think much that the boat would fit but common sense should tell me no i dont have enough room to have another trailer so my thought here is that can cut it behind the toungue where it hitches and slide another piece of square tubing inside so it can slide i can double pin it then and my utility trailer is now longer so the boat fits and when boat isnt on it i can shorten it up what do u guys think
Fishing Dude too
Re: fitting 14 ft vhull flat bottom metal fishing boat on a 7 ft snowmobile trailer
Why not just flip boat upside down, moved forward on tongue, strap down, lauch without backing all the way down the ramp. Will be hard on wheel bearings getting wet, lights not water tight, and square tubing may be odd size to find a slide over peice, pluse may break out due to metal fatgue where pins are. Just giving an idea.
brianis
i put a deck on the boat so to heavy to flip by myself so i should probaly buy a little trailer from say harbor frieght
Fishing Dude too
You could buy an axle and make a t trailer
V153
Math wasn't one of my stronger subjects but to fit a 14' boat on a 7' trailer I reckon you'd have to cut in half ...? Sorry
brianis
i was thinking about buying a axle and making one but an axle isnt cheap and by the time its said and done a trailer from harbor frieght is 330 bucks
oldjeep
7ft snowmobile trailer? From the 60's or something? The shortest ones you can get now are usually 10ft
JB
First, is it a Vhull or a flat bottom? No such thing as both.
Really, really bad idea, brian. Get a trailer that it fits before you kill yourself, or worse, some innocent bystander.
brianis
yea think ill get a trailer and what do u call it if the front is shaped like a v and the bottom is flat and this boat is metal not aluminum i havent figured out who made it or what
