Engine in question is a 1966 Evinrude 18hp
When I first got into outboard repair, this was the first engine I ever 'fixed'
6 years ago, I resealed the gear case, replace the impeller, gave it points and coils, redid the carb, new fuel pump, and painted the exhaust housing and lower.
It has seen 5 years of good use. 6 months out of the year, it sees about 20 hours a month. It is used by every visitor to the familys river property.
Stored out in the 120 degree sun, and never winterized.
A year ago, it stopped pumping water, but was used anyway. It mad it about 300 feet before the engine seized up.
after it seized and cooled, the engine freed itself up, started again a few days after the fact for a few seconds, and it has been sitting ever since.
Retrieved the engine, gave it a few good coatings of Raid.
and did a compression test this morning.
90 psi on the top
120 psi on the bottom
Think its just a simple head gasket? or is it done for?
The engine has other problems too.
bot transom clamps are now broken, the 4 rubber hood pan mounts are broken. the pull-starter handle has been replaced with a broken screw-driver.
It'll need new fuel lines and a good cleaning.
90 psi on the top
