Fixed my leaking trailer bearings
sdunt
OK, this is NOT an attempt at commercialism.. Just that I found a great product (thats CHEAP) and you all might want to know about it.
My trailer bearing seals were leaking because the 50 year old axles had worn and pitted, etc so there really wasn't a place for the seals to seal to.
I found this product called Spindle seals from the Bearing Buddies people for $12 per axle and it fixed by problem. No grease out, NO WATER in.
I made up a share a project with photos, etc..
http://www.shareaproject.com/pages/projectTut,p,373,00.html
Scaaty
Re: Fixed my leaking trailer bearings
Sounds interesting!
Frank Acampora
They also sell them at commercial bearing supply companies. A sure fix for pitted or worn spindles. If mine ever go bad, the first thing I will try will be a pair of them.
