I originally posted my question a week ago or so and is here http://forums.iboats.com/showthread.php?t=242101
I put a new lower shift cable in along with water pump (mine had cracks and was pretty much destroyed) and got the boat back together. ADJ the shift cable per the Manuel and I Still had no reverse. I know reverse works cause I tested it while I had outdrive hanging from my rafter and it worked fine.
What I found was the brass shifting arm mounted to the gimble (not the one on the outdrive) had some slop in it. Like its worn out a bit. I shimmed it and that fixed the problem. I get FWD and REV perfectly. Anyone ever here of that wearing out? When I got the boat I had to order a new shift arm (the part thats in the upper section of the outdrive) due to it missing.
Any way if anyone is having any similar issues and have swapped cables and still cannot get a solid rev lock check out the brass shifting pieces.
Later,
Big-E
Later,
Big-E
