tlocus73
- Joined
- Aug 18, 2008
- 51
Hello,
Was having some Tach gauge/reading problems such as intermitant readings, then drop to '0'. Also when at '0' increasing the throttle would make the tach read rpms again.
Started to go through all the wiring, continuity, remove misc. corrosion, etc...
Also, a while back, I had the VRO pump disabled (a few lines plugged and a wire added or rearranged? ...can't recall).
There is a cable with a plug coming off of the main red connector inside the engine. This connector cable contains 4 wires which I believe are; white, grey, purple & tan). These go to the VRO pump.
Even with my VRO pump disconnected/not used, do I still need to have this connected up to the VRO pump?
Is the grey wire in this harness related to the Tach.? (I believe I did a continuity test and it was connected to the grey tach. wire on the terminal board in the engine.
I have a few pics below.
This is the remote control box diagram. This is pretty much an exact match to mine.
This is in the engine. There are a few differences: terminal block wiring is not the same, and not exactly sure about the 'remote control' connector is wired up(different than on the actual remote control). Also there is the connector/cable that goes to the VRO pump (not shown in this diagram)
And here, a rough hand drawn diagram of how the VRO pump is connected. ***White wire is actually Black
Here is a pic of the VRO connector on my engine:
Any help appreciated,
Thomas
Thomas
