Hello, the flexible rubrail has pulled out of the plastic sleeve. The plastic sleeve is screwed to the boat and the flexible vinyl part that slides into the plastic sleeve has shrunk and pulled out of the sleeve at the inside corners of the bow pulpit and one of the stern corners.
What is the recommended fix?
The rubrail is in good shape except for this problem.
If i heat/stretch it back in place it seems to me that it would pull out again with the changing temps.
