flat top pistons
scottn83
I am rebuilding a Mercrusier 3.0L and i have access to a set of flat top pistons for 1/2 the price of the new ones from a online supplier . The pistons that came out of the engine have a d cup in the top. Can I use the flat tops in this engine or can they only be used in the 3.0LX.
Re: flat top pistons
Ayuh,... Possibly....
You'll have to cc the heads, 'n measure how deep the pistons are in the block, at Tdc to see what the compression ratio comes out to...
If it's much over 9:1, you'll probably have detonation issues...
CharlieB
Pay close attention to what Bondo has said.
The 'installed height' of the piston can be different, they 'could' be a direct replacement, but then again, they 'could' be way different.
To get a rough idea of the difference, set one of each pistons ON their head next to each other and look very closely at the connecting pin location, if they are the exact same height then the flat top would make more cyl pressure than the dished piston as the dish will add volume to the compressed area.
This difference 'may' be recovered using a thicker head gasket.
It will save you a LOT of time and effort to use the correct parts as the factory has already done the engineering.
Not saying that it can't be done, just why bother, running on the water is NOT very forgiving if your motor isn't 'right'.
scottn83
it ended up not being an issue the machine shop just called said we are going to go .20 over anyway so i will just get my machine shop to get me a price and see if he can beat the guys i got it online from
Thanks everyone for your input
this site has been full of a lot of good input
