roscoe
- Joined
- Oct 30, 2002
- 21,750
Do you seat the hub parts together before installing on the prop shaft?
In other words, do you press/hammer them together?
I have read that some people do.
Have also read that it is not needed.
Just install, then torque to 100 ft lb to seat, then back off the nut, 55 ft lb being the minimum.
The reason I ask is that last fall during fall maintenance, I found that my delrin insert was cracked in several places, like I had a hard prop strike. The prop was a tiny bit loose. But my prop shows no damage at all.
I was thinking that my install may not have been done correctly.
What is the proper way to install?
Or what do you do?
Or what do you do?
