I purchased a boat a few months ago and found out the fuel gauge doesn't work. I tested the gauge itself and there is continuity through the whole gauge, so the problem has to be with the fuel float.
here's the problem, the person I bought the boat from sealed the whole floor with one sheet of plywood and covered it all in fiberglass so there is no access panel. I need to know approximately where the fuel float is in relation to the doghouse (engine cover) so that I can make a whole to 1) install an access panel and 2) more importantly replace the fuel float.
I have a 1987 Four Winns with a MerCruiser 165HP 4cyl engine.
I was told by someone at a boat shop that it should be about 12 inches from the engine cover dead center in the middle of the floor but I want a second opinion because you can't "undrill" a hole.
Someone in another forum made a good point - since the previous owner replaced the gas tank the float may be in a different location, however, it appears that the original wires going to the fuel tank are still in tact so I'm pretty sure it hasn't been moved too far away.
