Duff that doesn't always mean a stuck float, it could be dirt (knocked loose from the inside of a fuel line when it was serviced before) if you have a stuck float it will usally come loose by tapping the float bowl with a screwdriver pull the carb and pressure test it is the best way to tell the problem
