Float Switches
chth
I have a Bayliner Capri and I would like to install a float switch. Is there one I can easly hook in between the bilge pump and the battery that will come on when I'm not at the boat for a while? If so what's a good one to buy.
crazy charlie
Re: Float Switches
Attwood or rule make good quality.Personally if the bilge pump you have is an older one I would replace it with self contained unit with the float switch built in.Charlie
Tufan
Re: Float Switches
I have two bilge pumps on my boat.<br /><br />There is one with the float switch and directly connected to batteries and other one is on manual that I can turn on & off when the auto fails (if ever).<br /><br />I highly recommend this set-up.<br /><br />I am not really sure which is the best brand, I buy these things from West Marine and replace it at least every two year.<br /><br />That self containing unit is really good by the way for the one directly connected to batteries, I dont have a float switch for the manual pump/
walleyehed
Re: Float Switches
I don't care for the built-in type pumps/switches...but if installing a float switch, install a new pump as well if it's 2 or more years old. Install the float switch so it's about 1/2 inch above the pump bottom in the "down" location as some will continue to run about the time the pump starts cavitating, and won't shut off.
chth
Re: Float Switches
Thanks for the info. I never give it a thought to replace the pump also. Good idea. I guess if your going to fix something you might as well do it right. Thanks again.<br /><br />Tom
cuzner
Re: Float Switches
Hey Thuges... When istaling, make sure float faces rear of boat, this will help prevent stuff floating in your bilge getting jamed under float, causing it to stay on and burning out your batt.<br /><br /><br /> Jim
18rabbit
Re: Float Switches
I moved away from mechanical float switches because they are vulnerable to just about everything, but they’re cheap. The problem with an unattended float switch is getting stuck in the on position and taking down the battery…or getting stuck in the off position an allowing water to accumulate in the bilge.<br /><br />This is what I got:<br /><br /> http://www.msc-emd.com/sensaswitch.shtml <br /><br />Field-effect circuitry imbedding in the plastic senses a change in the electromagnetic field when water gets in the vicinity of the sensors and activates the bilge pump. No moving parts, nothing to corrode, small, lightweight, easy to install, not affected by the boat’s movement, not cheap at about $30.
