float
markntexas81
Could someone post a pic of what the float on the carb looks like on a '84 evinrude 35hp 2 cycle. I took the carb apart and cleaned it, but im scared i may have put the float in upside down.
Marvxyz2
Re: float
I put my float upside down on my 5hp, and it didn't hurt anything , but obviously the motor wouldn't run right.
Marvxyz2
Re: float
when you are looking at the installed float you should see the tab facing you.
Elbo
Re: float
Pin the float with the tab hanging down.That is part of the float travel.
bktheking
Re: float
Looking the float i will have a flat side , the other side will have in indent, the ident goes downward toward the float boal.
Elbo
Re: float
#5 Today, 08:02 PM
bktheking
Re: float
Explain ur post?
bktheking
Re: float
The indent is to clear the orifice cavity in the carb bowl.
F_R
Re: float
ALSO, there is a little tab that bangs up against the float valve to limit the amount that it will drop down. If upside down it would be free to hinge way down.
markntexas81
Re: float
It seems like common sense would tell you to put the indented side toward the bowl. Im sure thats what i did. I dont want to have to take it apart again, what a hassel. Thanks everyone!
