Floatation Foam??
Uncle Dave
Greetings,<br />I had to remove all foam from my cuddy to facilatate hull repair. It was poured and had to be chipped out. Most chunks are the size of footballs. The foam took on no water even though water was presnet. I will repour the foam before replacing the deck. Question is Can some of the chunks be reused when repouring? Has anyone tried this?<br />Thanks,
JasonJ
Re: Floatation Foam??
If its not waterlogged, go for it, it'll save you a couple bucks.
